virusss
virusss's Avatar
08.29.2009, 06:50 PM
Motor mount is made by Serum :) Super nice work
I use the brake stock system (mechanical), with the motor brake the esc make too hot, stop a 11 kg of car is difficult for esc.
i don't use a clutch the pinion is connected directly to the motor shaft
othello
HV basher
08.30.2009, 05:22 AM
Very interesting browsing your eagletree file. I made a quick sum up graph while zooming into 1 minute of your run (mostly speed runs):
Virusss, do you know your overall gearing? Which pinion size do you run? Judging from rpm and voltage level i suppose you run a Neu 2215 2.5Y (600kv), is this correct?
With 5000mAh and a more constant / agressive power use (especially when running higher output batteries) i would expect runtimes to drop below 10 minutes (more then 500mAh per minute) and an average power of 1KW. You might want to get higher capacity batteries.
virusss
virusss's Avatar
08.30.2009, 05:53 AM
Wow Othello, very nice explain my eagle tree file...
yes the neu is 2215 600 kv
the gearing is 17/57 (stock)
my runtime approx 18 minute if i remember correct
i like to try 35c hyperion, and i like to try in offroad
p.s.
i like so much your video with eagletree file in overlay...how did you make?
othello
HV basher
08.30.2009, 05:52 PM
I am using a hyperion G3 3s 2200mAh vz 35C lipo and it performs great in a 1:16 buggy. Built quality seems top. Recharging with 10A (max 5c) takes about 20 minutes. Capacity although is only 2050mAh and not 2200mAh.
I posted some guidelines on how to insert eagletree data into a video about one year ago.
This is my latest video with eagletree inserts featuring my custom 4wd Baja based on 2 1:8 truggy chassis.
