Mystro
08.29.2009, 08:45 PM
The Monster looks like its the way to go. I have heard from a mate that the MMM doesn't really like "cheap" batteries and the zippys wont really cut it....whats another good brand Lipo that wont put me out of pocket?
Bl RVO: I don't know what you mean about having chassis flex because the Hyper St pro's shassis is very stiff...?
brushlessboy16
brushlessboy16's Avatar
08.29.2009, 08:57 PM
your mate is full of it then. As long as you have some idea of the power needed to run the system a zippy battery will do fine. High MAH and high C rating.
Look into the 5000mah 25-30c turnigy packs.
08.29.2009, 11:11 PM
What center diff did you use? (you mentioned it came w/o the spider diff)
what tooth was the center spur?
Thanks!
Mystro
08.30.2009, 12:30 AM
Also, what diff oil would you use in the centre diff?
08.30.2009, 02:01 AM
I put ofna diff lock lube in my center diffs. I only bash, it works well for me. Lots of wheelies and no unloading to the front.
08.30.2009, 02:05 AM
All vehicles have chassis flex.
08.30.2009, 02:39 AM
yep, which is why RCM mounts are the bomb diggity. "Flex all day and your mesh won't go away"
florianz
08.30.2009, 05:54 AM
the mount looks shiny!! I like!
but, I wonder if just two screws are stable enough. you should also have a connection to the center diff. what about combining the first and the second mount?
that's what I mean:
since my mount is built like that, I have no problems with spur gear etc.
I really like that hyper st, one day I will get myself one too.
flo
