Rivermaxx
08.30.2009, 02:59 AM
If you are stuck with 6s and the MMM your last setup seems to be the way to go. You may be near the limit of the MMM.
I'd go for a 1600/kv ish 1521 (or even 1527, go big!) and a 12s plane esc. They have drag brakes, your vehicle will stop! The CC HV110 is the boss, but a hobbycity "turnigy" unit has been proven to work well.
although the braking requirements of the ISC may not be met.
With 6s you'll really be pushing all of the components.
Biggest problem is the gearing I am limited with the g1 maxx tranny.That why I an going with a higher kv motor. I really dont want tire spinning or wheely torque. I want a gradual ramp up to the 100 mph barrier. I wish mike would get those center diffs out so I could get one, it would solve alot of issues. Why dont you let me borrow yours harold so I can break some records. The car does have to have brakes I believe in the ISC event.
