Unsullied_Spy
Unsullied_Spy's Avatar
09.02.2009, 03:56 AM
67 degrees Celcius is about 150 Fahrenheit, that's a perfectly acceptable temperature for a motor at the end of a run. Good job!
othello
HV basher
09.02.2009, 01:17 PM
Thanks for wheighing a baja tire/wheel. 480gr is more then i expected. A complete set of Baja tires should wheigh around 1800gr. That's about double the wheight of a 1:8 monster/Truggy tire set. Acceleration will suffer, amp draw will increase and runtime will be less. Hmm ... i would also have a smaller trackwidth with baja wheels as they seem not to provide enough offset compared to half offset truggy wheels. And the 24mm hexes are another story. I never saw those savage 5t hexes for sale. Guess i will stay with truggy tires. But i'm really interested in your "practical" results while running those "original" Baja tires.
Concerning the long center drive shaft. After my last run i spotted a place where the aluminium tube started to twist. I will also rebuild it. I think the easyest way is to replace the aluminium tube with a steel tube ... this should provide enough strenght.
I also thought about closing the front sides. Should provide more protection for the electric components and the center gears.
