brushlessboy16
brushlessboy16's Avatar
09.02.2009, 01:03 PM
Buggy on 4s = ~250mah/min @ track
My Revo on 6s/4200 pack = ~160mah/min @ track
Mind you that is two different owners here.... the buggy number is from a guy at the track, he's fast around the track, and still uses a 'nitro finger' for throttle, so that number should go down as he adjusts.
sweet.
My 8ight comes up at 8lbs flat in race trim with a 1515, 4s 5000mah pack, bow ties and a personal transponder.
anyone else know there specs?
Ryu James
Ryu James's Avatar
09.02.2009, 06:44 PM
thats cool. my 8ight 2.0 comes in at EXACTLY 8lbs also. that is with bow ties, 5s 3850mah, hacker c50 7xl in a tekno 44mm mount, my homemade 3mm carbon chassis, and pers. transponder too.
Jammin SCRT10 Neu 1512 1y
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.02.2009, 07:00 PM
What's your mah/min range there James?
Ryu James
Ryu James's Avatar
09.02.2009, 11:35 PM
i have no idea. how would i figure this out? i have the hyperion charger and i have been told that i can look at how much mah i have used after a race but not sure how to do this. if i knew how to view the used mah after a 10min main then its just simple math to know the mah/min.
