scarletboa
scarletboa's Avatar
09.02.2009, 10:35 PM
Originally Posted by J57ltr View Post
Is the brown stuff on the caps leaking from the slits on the top,(can't really tell.) If it is and usually a cap electrolytic will pooch out at the top or start to seperate from the bottom, or just leak.
Adding the caps to the input isn't going to help if that is the case you will need to replace the 3 mounted to the board, Shouldn't really be that hard. Each cap is in parallel with each phase not the input. The Mamba Max is setup just like that. I'll give you $10 for it.
Jeff
there are a few problems with replacing the caps. i don't know a safe way of removing the old caps, and the new caps need to be a specific size. otherwise, the two halfs of the esc won't mesh together right. i'd be willing to pay $15-20 for someone to repair it for me.
J57ltr
09.03.2009, 01:12 AM
Send me a PM, the parts and inbound shipping is going to be around $12-$20, unless it's something I already have in our stock, or around the corner. I'd like to see one of those VXL's
Jeff
Edit: And I wouldn't run it until it's fixed.
