09.04.2009, 12:25 PM
http://www.rc-monster.com/forum/show...18&postcount=6
They are a pain in the ass to programme for sure, hopefully that helps.
GTBB
09.06.2009, 09:19 AM
thankx for he info....will try tonite.
a6m532
09.06.2009, 10:45 PM
Hi,
I have a 16025, and has managed to programmed it using the usbcom is less than 30min. You must connect the usbcom to the esc and the pc, activate the program before you turn on the esc. After you did all the connection and activating the software , just turn on the esc, the software should be able to recognised the esc immediately. Try a harder brake setting, the original brake setting is next to nothing. For the transmitter limit use programed option, you would only be required to programed once. After doing all the setting switch off the esc, disconnect the usbcom. Turn on the esc, and use your transmitter to program the limit, after you finished the neutral setting, turn off the esc.
The Next time you turn on the esc, it will be programmed and ready,
GTBB
09.07.2009, 02:38 AM
Originally Posted by a6m532 View Post
Hi,
Thanks a lot bro.
