Go Back   RC-Monster Forums > Support Forums > Team Tekin
09.05.2009, 08:19 PM
Yep...sounded like you demaged the motor a bit...especially when you hit the 220 mark.
Send it back to have them work on it. Their tech support is excellent.
FG101C
09.05.2009, 10:10 PM
Upon further inspection, I decided to take the front plate off and check the bearing. Bearing is perfect, no play and smooth as glass, so I pulled the rotor out to check it. Well the kevlar or whatever, fiber wrap around the rotor is pretty badly frayed and separating from the rotor. I had a 60mm Medusa do this once, they replaced the rotor and good as new.
