Marvin
THE Paranoid Android
Marvin's Avatar
09.07.2009, 11:43 AM
I'm afraid that the two centre diffs are very diff-erent (oh the pun!).
The 9E uses a 'short' centre diff, like the mini truggies and a 40T spur, whilst the nitro version uses a full-size centre diff and something like a 46T spur?
I suppose you may be able to fit the 40T spur to the nitro diff, you'd need all the 9E's diff mounts due to the varied height. You'd also need to check hole spacing of both diff mounts, as the 9 nitro's holes may be further apart.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
Cain
09.07.2009, 12:33 PM
A thought on keeping the inside cleaner, since people use pieces of lexan to act like shields for the rear driveshafts, it could be possible to do the same for the electronics, say from between the ESC and servo back to the motor? I am thinking something like this:
motor ESC | servo
__________|
Where the lines are the lexan. You could even bolt the lexan underneath part of the servo motor and the motor mount depending on how you bend it, depending on high the lexan shield is, you could make it tall enough that the force of the body coming down on it could hold it down, or rig something like a little lip for some servo tape.
FG101C
09.07.2009, 12:54 PM
The 9e and nitro use the same diff and spur.
Marvin
Marvin's Avatar
09.07.2009, 01:32 PM
Yes you're right. Just had a look at OFNA's website. I don't know why I thought they were different.
Originally Posted by lambchops View Post
Can anyone compare the part numbers to the centre diff mounts, the nitro uses parts 89042 for the upright diff parts and 89040 for the metal top brace and 89004 for the diff case, what does the 9e have in the manual?
Going by OFNA part numbers (as the manuals are on their website), 29004 is the diff case on both the 9 and 9E. 29045 is the spur on both.
The part numbers (20942) are the same for the centre diff mounts on both. It looks like it will work! The only bits you'll need are the motor mount and a battery box.
