Unsullied_Spy
Unsullied_Spy's Avatar
09.10.2009, 03:20 AM
and is castle going to void the warrentys on the ICE as soon as we put it into a car like you guys did with the hv110?
Are you asking if Castle would release a product and not back it up? I suppose it's possible that they'll release a firmware swap for it with a disclaimer that any damage won't be covered under warranty (though they'll probably still cover it as long as you don't deliberately burn it up). If they're releasing a car-specific model I have every confidence that they'll have out backs on it. I'm still twiddling my thumbs waiting for that Marine version...
Originally Posted by rotary rocket View Post
Would the ICE 12S controller work for 1/5 car application?
If yes, what motor would be a good fit?
Great news by the way. I have been waiting for such a controller for a real long time.
Up to 12s lipo at up to 160 amps, by my math that's over 7,000 watts with the lipos at nominal voltage. That should be plenty to handle a 1/5th scale.
I would say it depends on your application. MasterBlaster's Baja has a Neu 2215 in it and it goes like stink! The highest KV I would go for is the 2Y on 10S, go lower KV and more voltage if you can. A Neu 2230 will power any 1/5th scale R/C currently on the market as long as the ESC and lipos can handle it but that is a $700 motor capable of putting out over 13 HP.
Semi Pro
Semi Pro's Avatar
09.10.2009, 04:51 PM
i used to think that too, untill they said we were voiding our warrentys by useing them in cars
Pdelcast
Pdelcast's Avatar
09.10.2009, 06:05 PM
That's because the Phoenix-HV was never designed for use in cars, doesn't have the right hardware for cars, and doesn't have the right software for cars. So we don't warranty them for use in cars, or power tools, or sex toys, or anything non-airplane.
If we decide to release a car version of the ICE-HV, it will be warrantied for use in cars. It's possible that the car version may be exactly the same as the airplane version, but not definite yet -- we haven't done enough testing to make that determination yet.
Patrick del Castillo
President, Principle Engineer
