Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
MetalMan
MetalMan's Avatar
09.17.2009, 02:22 AM
Originally Posted by Rivermaxx View Post
I know there is a switch that makes it so you can turn the third channel on and off like a light switch.
The 3rd channel will do that with a servo or any other device designed to operate on 1-2ms pulses. But so long as the fan is plugged in and the receiver has power applied to it the fan will blow, regardless of the 3rd channel (or any channel for that matter).
webracer
webracer's Avatar
10.19.2009, 02:56 PM
I think you could try a battleswitch (www.dimensionengineering.com). We use it on RC planes and helis to launch bottle rockets and such. Problem is you need a separate power source for the fan (maybe another open slot (like the bind/batt slot on Spektrum) to power the fan).
Troy
I am now free to exercise my downward mobility
rchippie
rchippie's Avatar
10.26.2009, 03:27 PM
I just orderd the castle blower for my ERT . My temps are fine with out it . But a little cooler never hurts electric componets .
REAL MEN RUN BRUSHLESS
rchippie
rchippie's Avatar
11.02.2009, 03:44 PM
My blower showed up today, It looks pretty cool . Im going to order a couple of 30mm fans for spares . I also shortend the wires off the fan & ran a servo extention cable . So i can just plug the fan in on the side on my MMM, with out having to route the plug all the way to the reciver. This will make it alot eaiser when i have to replace the fan .
ID:	7925   Click image for larger version
myndseye
myndseye's Avatar
11.11.2009, 01:35 PM
Try one of these
http://www.robotmarketplace.com/mark...mdelta_rc.html
http://www.dimensionengineering.com/PicoSwitch.htm
powah
12.03.2009, 09:48 AM
I just received 2x CC Blowers and i feel robbed
On the picture that Castle show's on their website http://www.castlecreations.com/products/cc_blower.html it looks like it's made from alloy and looks good.
The real CC Blower is made from very cheap plastic and looks like crap.
When you look at the top of the fan it looks like there are grooves op top of the fan for extra cooling.
The real CC Blower has a sticker on it with white stripes that looks like grooves for extra cooling.
When you look at the picture of the CC Blower you didn’t see a wire for the receiver to power up the fan.
The real CC Blower has a very short wire that's to short.
brushlessboy16
brushlessboy16's Avatar
12.03.2009, 02:05 PM
Its a rendering....
bruce750i
bruce750i's Avatar
12.03.2009, 04:02 PM
If you wanted to you can route the wires out of site. Just pull the fan wires and plug through to the inside of shroud, then hold the wires down the side of the motor (inside of a row of fins at least three fins from edge of shroud) as you snap the fan shroud on the motor. Doing this leaves a small hole/air leak where the wire use to exit, I just hot glued mine closed.
