It’s always better to reduce the heat generated in an electric power system is by better engineering than to try and cool things with fans and other gimmicks. Sure, a fan can get you a few degrees, but it is much better to have a superior design to begin with.
Contradiction?
Whats the flow rate of the fan?
Use at your own risk,your just covering up a problem. Not geared right.
There's a big difference between using a fan to make a hot, overgeared setup barely usable, and using a fan to keep a cool, properly geared setup even cooler.
