Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
redshift
RC-Monster Square Tube
redshift's Avatar
09.19.2009, 10:34 PM
Total envy.... and what's up w the shorts? It's 30 (0C) here! Is it really that warm up there....
Truck came out superb man... howbout a shot w the body on tho
Fantastic work!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.19.2009, 10:54 PM
Sounds like you switched the Kv on the motor... Did you? Also- I can't believe the Sentilon can run that motor...it just doesn't seem right.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.19.2009, 10:57 PM
Setup looks spot on! With most of the 5th scales I've seen, it was like putting a fiegao S motor and a MM in a savage. This looks more like putting a MMM in a savage! What it should be. Temps look really good too. Looking forward to more videos if they get made!
Will make more videos for sure... Headin' out to the 5th scale track tomorrow.. too bad I don't have any buggy tires to test it out with on the dirt.. Once I feel up to it, I'll pull the SHV240 out... I'm really surprise this $100 ESC is powering a 35+ Lbs Monster Truck.. HAHAHAH
Fantastic work!
0 Deg C... woaah.. that's cold.. it feels about 25 Deg.. just cooled off to 15 Deg C. now...
Aren't there some pictures with the body on?... I'll post it up tomorrow...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Nard Cox
n00b
09.20.2009, 04:47 AM
Man those temps are godlike :)
Curious to see what it looks like in daylight.
aqwut
aqwut's Avatar
09.20.2009, 08:28 AM
Heading to the 5th scale track today.. I shall have some Day videos.. and gears to swap... I think the ESC will hold up very well, I don't even think I'm going to change the windings on the 3080... I'm just going to leave it @356KV...
I'm working on the Panty Hose Mod right now. After last nights run, the truck is full of pollen, grass, weeds, etc... Have to find a K&N Filter that will fit over the End Of the 3080.. that way it can have good air flow.. I think, a piece of grass made it in the motor last night.. hopefully, I got it outta there...
aqwut
aqwut's Avatar
09.20.2009, 06:13 PM
Update: Modified it to have dual steering, since I have another 805BB hanging around, might as well use it. Also did the panty hose mod for the back of the Lehner 3080 Can. Keeps out the grass and other things from being sucked in.
First video is 27/33 Gearing.. As you can see, stripped the plastic gears again (25T/25T). I have no other option, other than going to metal gears..
[youtube]CUNzBAsYgYQ[/youtube]
[url]http://www.youtube.com/watch?v=CUNzBAsYgYQ[/url]
aqwut
aqwut's Avatar
09.20.2009, 06:19 PM
This video is 33/27 Gearing… Again.. the gears stripped(33T/27T).
[youtube]9gf77csrP1Q[/youtube]
During/After the whole run the motor was 42 Deg. C, ESC was 49 Deg. C and batteries were about 40 Deg. C.
Now it runs with 29/31, until I get some metal replacement gears…
Semi Pro
Semi Pro's Avatar
09.20.2009, 06:23 PM
very cool truck
over all what do you think it cost you to build?
aqwut
aqwut's Avatar
09.20.2009, 06:30 PM
very cool truck
Motor was about $800, ESC $100, Batteries $200, Piece of aluminum $12.... Red Cat roller with Gas engine $550. Subtract $250 for the sale of engine and pipe..
lutach
lutach's Avatar
09.20.2009, 07:33 PM
You might have to get some metal gears for this monster. I like how it has the power to pop a wheelie even though you're still using the conservative winding.
aqwut
aqwut's Avatar
09.20.2009, 09:37 PM
I know, I'm almost scared to change it to the higher Amp winding... it has so much more potential... I will order the metal gears for sure.. I saw the set of 4 Gears for $64 ...
Ryu James
Ryu James's Avatar
09.21.2009, 01:16 AM
very cool vids aqwut. dude, i saw that the lehner 3080 is capable of 11000 watts. thats nucking futz!. i am worried now that my 2215 isnt going to be enough and run too hot. i am looking at getting a 2230 maybe or a lehner 3060. the 30 series motor fits my motor mount perfect so i can use either a neu or lehner but after reading about MBs motor failure on 8s i am worried whats gonna happen on 10s with the same kv and i have the lowest kv 2215 without a custom order. 11000 watts. thats like 15 hp or something crazy. no wonder those temps are so low. that motor isnt even having to try to pull that thing around. we'll see what my 2215 does but i have a feeling i will be upgrading very soon.
Jammin SCRT10 Neu 1512 1y
aqwut
aqwut's Avatar
09.21.2009, 06:50 AM
Dude, I think you're 2230 would be awesome in that truck... but I don't think the 2215 would have any problems either... Lehner use to put out Excel sheets for their motor data, but they don't have it on the site anymore.. Luckily I downloaded it soon as the 3080 came out.... So it shows all the max continuous current that could go through the motor...
My current setup is the star connection, and is capable of 200Amps and 50K rpm... On the triangle setup it's capable of 300Amps and 50K rpm..
So you have the 2215 3Y 480KV, 5000Watts Max @ 72 Volts = Maximum discharge would be about 70 Amps... so if you run 12S, the maximum power you could achieve would be 3100 Watts Peak.. so you really won't need a super expensive ESC.. You figure, my Rampage MT would be pulling Peak of 100Amps... I have not seen it hit that high yet with this setup... I always like going a bit bigger with motor size, just because it has so much more torque on lower KV... which in turns, gives you more voltage and gearing options... I think your 2215 would be fine.. What Wind did MB get for this Baja5B...?
virusss
virusss's Avatar
09.21.2009, 08:23 AM
I use in my baja one NEU 2215 600kv, and 10S lipo 5000 25C, the car go at 85kmh 20 minute runtime and temperature is: 49c° motor 50c° esc 35c° batt...
i like 2215 :)
Ryu James
Ryu James's Avatar
09.21.2009, 10:08 AM
actually i have the 2215 2y, which is 750 kv and i will be running on 10s. so tell me, you think this will be ok? when i bought my motor it seemed like the logical solution for 10s at the time but based on recent experiences and what i know now i would have much preferred a lower kv motor. i have been starting to sell my 1/8 motors and get lower kv options. my temps are usually right in the acceptable range but i like it when things run super cool. i used to think you had to spin the motor at 50k rpm to go fast. i have learned much since then. so anyway, what do you think of the 2y on 10s? MB had the 2y that he fried on 8s and that got very hot on 10s but he had the 180hv castle esc. i have the 240hv castle. not sure if that will matter. but also MB said that he later found that his gears were binding so i am not sure if he tried 10s after clearing that up.
anyway, i could be running mine right now if the damn esc would work. i have it all but finished and wanted to test it out but when i plug in a lipo the esc just blinks red one time and then nothing. anyone have any ideas? i havent been able to hook up 10s yet cuz i dont have the connectors i need to make a series link but i figured if i just plugged in one 5s that would at least let me get my esc calibrated and bind my rx until i can get to LHS later today for connectors. do you think the esc wont come on cuz its only a 5s i tried? does it need to be at least 6s being as it is the hv version?
my ramp is now 95% finished and i have posted several pics on my thread here in the forum. all thats left is add the disc brakes, mud guards, and a couple of finishing touches.anyway, i wanted to get your thoughts on this esc issue and setup.
what is your esc and where did you buy it? does it have braking and lvc?
oh, btw, have you seen these? http://innovativehobby.com/outerwear...hpibaja5t.aspx
this could probably work well for a cover instead of the pantyhose. just a thought. its pricey but i had looked at it. i have been able to use many parts from other 1/5s for my ramp. my outerwears motor cover is actually for a 1/5 gas crank case or something.
http://innovativehobby.com/15scalecr...oahmotors.aspx
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
