09.20.2009, 09:46 PM
Bondo, if that's what you want to do, let me say you are in for some work ahead of you! I had two 2s2p 8Ah packs and the tabs were so thin that simply desoldering them bent them enough to start tearing. Even the ones not soldered well tore easily.
If you still want to go ahead, you're gonna have to split all the cells apart. This means you will have to remove each 1s pairs, and then disassemble each 2p set until you have all 8 cells in front of you. Once you do that, let us know and we can go from there. But I honestly think you're gonna have problems with tab tearing.
