lutach
lutach's Avatar
09.24.2009, 02:36 PM
I did say 'looks like'...
So, hopefully these will turn out to be the new Medusa, low cost alternative to Neus...
I know. If you guys look in the rcgroups threads, I've mentioned something there about using the motor for car use and there were some doubts from the owner. I got to wait for and answer from the place that makes the motors to see if they can do one that can be rebuildable. Good thing one person here will try one out .
florianz
09.24.2009, 05:04 PM
well, the medusas have been used a lot in planes, too, before the became popular for cars, as far as I remember. and surprise - no problem.
when these motors /the 75-55-1/ works on 8s in a plane, 6s in a truggy should be ok. sure, you can't get the same cooling in the car like in a plane...
the efficiency seems to be good, the 55 at least seems to be better then the hxt quannum, which is no bad motor at all.
here in germany there have been successful tests with a quannum for offroad-use and a mega as well. so I don't know why there should be a problem. the more poles, the better for partial load, wich is typical for cars.
lutach
lutach's Avatar
09.24.2009, 05:13 PM
Did you see my video runnung the longer Qannum motor? The rotor exploded lol. The problem the Dave said is with the load when the vehicle jumps. I told him RC-Monster makes a nice heat sink/clmap system and he agreed it's the only way to go. So I've been waiting for someone to get one and try it in a vehicle . I'll be checking for the results.
florianz
09.24.2009, 05:42 PM
just recently a guy's castle-neu rotor exploded. and my losi would have exploded as well, if I didn't seal the rotor bonding which was getting loose due to sand. even the lehner's loosing segments... they all can fail. but when the arc's not bonded, that might be a problem. I can't forget that statment of the 75mm on 8s. surviving that, I think they're solid, but I think we wil find out
