Mystro
09.25.2009, 07:08 AM
Pictures don't work.
I have solved the problem by using a mount i previously made. It's a beefy version of the RCM mount. Just need to fix a small problem with the mount and clean it up.
I also have the problem with the pinion coming off the shaft all the time. I have put loctite on the grub screw and will test it tomorrow.
Any other ideas if loctite doesn't work?
florianz
09.25.2009, 07:16 AM
maybe the mount is not parallel/in line to the diff, so it pulls the pinion off.
loctite should help. is the flat area on the shaft still ok?
