Maxxrickard
Maxxrickard's Avatar
09.25.2009, 04:49 PM
what to do? its 3 weeks ago i gave mike my list of stuff... i dont give me any answer!
i think i will order from some other shop..
my problem is the diff. i looked at Front/Rear Differential Lightning in mikes store but it is out of stock and i cant find it anywhere. is it an old model?is it possible to use the "pro" model:
http://www3.towerhobbies.com/cgi-bin...&I=LXLGX0&P=SM
pinoin:
http://www3.towerhobbies.com/cgi-bin...&I=LXJBM3&P=SM
i will use MMM 2200kv combo and i think i will use the gearing 18/68 in the beggining...
sorry i found it at amainhobbies.
BUT is it possible to use the pro anyway?
JoFreak
JoFreak's Avatar
09.26.2009, 11:59 AM
Are you serious???
Asking questions somebody allready asked somewhere else again is OK, no one can read every thread in every forum and memorize it.
But you could at least remember the questions YOU allready asked and got answers to, especially if it was in the same thread:
Originally Posted by JoFreak View Post
The Pro diffs are from the truggy version, means they have a smaller pinion gear.
Since you want to use a tranny you should use the non-pro diffs.
okey a non-pro diff.
And yes, Neil is right again, as I was back then: you can't use the pro diffs unless you use a center diff because otherwise your gear ratio would get messed up.
About you order: You sent a PM to Mike telling him that you sent him an order via e-mail?
