JoFreak
JoFreak's Avatar
09.26.2009, 11:59 AM
Originally Posted by G-revoRickard View Post
is it possible to use the "pro" model:
BUT is it possible to use the pro anyway?
Are you serious???
Asking questions somebody allready asked somewhere else again is OK, no one can read every thread in every forum and memorize it.
But you could at least remember the questions YOU allready asked and got answers to, especially if it was in the same thread:
Originally Posted by JoFreak View Post
The Pro diffs are from the truggy version, means they have a smaller pinion gear.
Since you want to use a tranny you should use the non-pro diffs.
okey a non-pro diff.
And yes, Neil is right again, as I was back then: you can't use the pro diffs unless you use a center diff because otherwise your gear ratio would get messed up.
About you order: You sent a PM to Mike telling him that you sent him an order via e-mail?
