emaxxnitro
emaxxnitro's Avatar
09.26.2009, 04:08 PM
adding
1. they have an advantage unless your pit guy can change packs fast lay off the reserve power, its not needed dont use it. now if its the last lap use it. a good pit man can refill a nitro in 5 seconds. a good electric pit man can change packs in 15 to 20 secs.
2. nitros have spool up to deal with you have wheel spin. really its a advantage to you. but if you break traction you can get on a power slide and roll it over.
3. the doubles, a good nitro driver can do the double-doubles consistently, a good brushless driver should do the same. dont go for the triple! sure its a show stopping move but its not consistent even though you can do a quad with bl its not practical and the speed you have to do a triple can hurt you on the landing.
808E
