nitrostarter
nitrostarter's Avatar
10.07.2009, 12:52 AM
Honestly, I would opt for the Hyperions. I have run the 5500's in my G4 maxx and everything runs cool. After 30 minutes of bashing the packs are 103-108F consistently. The power is intense and more the the Turnigy packs I ran, which temped at 130F when finished 30 minutes of bashing.
N. Rustler conversion
stum
10.07.2009, 12:58 AM
I'm not sure if comparing NeuEnergy and Turnigy is even close to fair... I have some turnigy 30c packs and they can't take 1/2 the abuse the Neu 25c's do. I have a 4s 5k Neu XP I run in my 8ight-e and that pack is pushing 2yrs old and runs like a monster still.
Thanks for your thoughts though
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.07.2009, 03:21 AM
Those Neu Energy packs are Enerland packs I assume? If so, the G3's are more than worth it, they should last alot longer, provide you with intense punch, and are just a better/newer cell chemistry plain and simple.
Ask Mike, he will say the same.
EDIT: Plus you can charge them at 5C, and I do charge them at 5C everytime I use them! 20 amps for the 2x 3s/4200mah VX packs. I must have done ~70 cycles on them by now, I use them multiple times per day and charge them right after each use, and out I go again... they never get over a few degrees over ambient (10 degrees tops) the whole time.
