stum
10.07.2009, 03:23 PM
Got the Hyperion g3's for 350 shipped, pair of the 6500's I'm pretty happy.. NOW they better perform and for a couple seasons! LOL In NY race season is short so if they are better than the Neu packs, it shouldn't be an issue.
reel
10.07.2009, 04:11 PM
Hi
on which voltage cutoff are you running your hyperion packs?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.07.2009, 06:08 PM
Nice man, you won't be disappointed with them, they will serve you well even if you don't.
reel, you would want to use a voltage cutoff of no less than 3.2, and 3.4 - 3.5 is preferable for these as these newer packs just hold so much voltage, so you can increase the cutoff the better a pack is, IMO. But, it also depends on your setup as well, when you are geared high and use alot of WOT, or if your pack is not over sized for the application you may want lower the cutoff.
