Is 2 hours possible? (Lipo receiver pack run time)
portyansky
Is 2 hours possible? (Lipo receiver pack run time) - 10.08.2009, 09:36 PM
So I got a lipo receiver in the Mugen. The last race I ran it was a 20 min main and I only used 300mah and its a 2020mah pack!! And that also includes some warm up time and a few practice laps, but lets say 20 minutes b/c its a easy number to work with.
So if I use 300mah in 20 min then that means I will only use 900mah in 60 minutes and 1800mah in 120 minutes. I just dont remember whats the deal about running the lipos down so low.
Reason I am asking is b/c I am gonna be doing a 5 hour (thats right, 5 hour) truggy endurance race. 1 team of 4, one chassis. Not having to come in for 2 hours for a battery change would be amazing!
So my question is, do you guys remember how low I can run the lipo?
bdebde
That's All Folks!
bdebde's Avatar
10.08.2009, 09:40 PM
3 Volts per cell is the lowest voltage recommended for lipos.
BP-Revo
BMW M Power!
BP-Revo's Avatar
10.08.2009, 09:49 PM
Also, remember that there are many things that depend on how much current you use. A track with more turns will draw more than a track with less turns, so it is advised to run some sort of device that can monitor the pack (some sort of telemetry would be great here).
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.08.2009, 09:51 PM
Go to HC website you might be able to find a even higher MAH pack to fit the radio box, maybe 5 hrs on 1 battery might be feasable ?
You might be better off with a 3s and a volatge regulator in a 2000mah and be able to get 5hrs easier ?
Someone with more knowledge should chime in sooner or later to assist more.
portyansky
10.08.2009, 10:24 PM
Thanks guys. I think I will try to run 100 minutes per pack. That's an hour and 40 minutes. But I will check with my team what they wanna do.
But more input from the people here would be helpful.
Thanks
whitrzac
Can't catch this...
whitrzac's Avatar
10.09.2009, 02:31 PM
strap a 2s 5000 to the side of the truck...
brushlessboy16
brushlessboy16's Avatar
10.09.2009, 06:54 PM
why not like a 4s 2500mah
and a castle BEC
whitrzac
Can't catch this...
whitrzac's Avatar
10.09.2009, 11:34 PM
and a castle BEC
cuse if it fails, your SOL... with a 7.4 you at least have a chance.
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
10.10.2009, 11:11 PM
lowering the voltage sounds like a waste to me.
think about it, ESC's are more efficient when going flat out (less FET on/off phases) so hence running a pack that can do 6v for the whole time would be better imo
