micke_b
10.10.2009, 02:24 AM
lol, oh. Not sure. I'd have to scrape the conformal coating off to find out.
Could you? ;-)
Also did you find out what MCU they are using? I know that the Mamba Max I have is using: C8051F320. But I think this one looks different. Do you have the part number for it?
Pdelcast
Pdelcast's Avatar
10.10.2009, 01:27 PM
Originally Posted by micke_b View Post
Could you? ;-)
Hmmm, why don't you ask me, since I designed the MM Pro?
And why are you so interested in the particulars?
Since you can find all this out yourself with a little research (and I really don't care if you know--)
FET drivers are commodity items now, everybody makes one -- and they all work very well (except for a few notable exceptions...)
The FET drivers are Intersil ISL6700IB. The processor is a Silabs C8051F367 at 50 mips.
The MOSFET is an NTMFS4933 (about 1.3 milliohm.)
(the NTMFS4933 isn't yet released to the public, and datasheets won't be available online until late January, early February. Castle gets the first run of wafers.)
NTMFS4108, BSC014N03s and BSC019N04s are suitable substitutes we may use if availability becomes a problem. (we use a half-million FETs a month, so sometimes we have problems with availability...) There isn't a significant difference in performance with any of these other FETs -- BUT, we do have to change the drive circuit values.
BTW BrianG: The production version shows almost no difference in performance between these different FETs -- the original Beta had an issue with drive speed on the 4108s -- the 4933 version you got had the issue corrected. Once the drive is correct, the different FETs have almost no performance difference.
Anything else you want to know? The switcher chip is an LTC3824 (Linear Tech), with an AO4421 (Alpha Omega Semi) external FET. The main inductor is from NIC. We are using a novel circuit to give variable programmable output voltage on the BEC switcher (I'm not going to give you details about how that works -- figure it out yourself!)
We are using a variable gain back-emf detection circuit. (Figure that one out yourself too!)
The fan and sensor connectors are from JST, and are not chinese clones of the JST part.
We use a TPS76133 (TI) regulator for main processor power (3.3V) -- And there are four total power supplies on the board (including the BEC supply.)
That about does it. Now if you want, you can run over to Novak, or Tekin, or LRP, or HobbyWing, or whoever and let them know. Good luck.
Patrick
Patrick del Castillo
President, Principle Engineer
micke_b
10.10.2009, 01:53 PM
Hmmm, why don't you ask me, since I designed it?
Patrick
Hi, thanks for the Answer Patrick. Of course I've should have asked you, just took the chanse of asking here since BrianG made me curious with all the pictures. ;-)
Im asking since Im trying to learn how these things works and I have a goal to try and build a esc of my own, but based on a AVR MCU. Sice I really like your products and it seems like you guys know what parts to use I thougth I save myself that trouble. I still have a lot to learn, but Im getting there.
Thanks for sharing.
Pdelcast
Pdelcast's Avatar
10.10.2009, 02:18 PM
Thanks for sharing.
The AVR MCU is a decent platform.
Building a good quality ESC isn't an easy thing. We have years of experience with it (Castle has been in business for 12 years!), and are still learning new things every day. Before starting Castle I worked designing avionics for Honeywell and Garmin.
A few things I didn't point out -- the main FET board is eight layers, six ounce copper each layer. Just tooling for a circuit board like that costs several thousand. You don't want to know how much we pay for each board.
The control board is .005" track/track, 2 oz copper, four layers. (that's an expensive board to tool too...)
The heat sink is a custom made for us by Aavid.
If you are planning to build your own ESC for your own interest, great. If you are thinking about getting into the business -- let me warn you. The margins are terrible, the competition is fierce, the distributors make you jump through hoops so they can make more money on products than you do.
Most of the manufacturers in this business don't do anything new -- they just wait for new products to come from their competitors, then they clone them, steal the ideas and designs, and then undercut your (already very thin!) margins. And that's just the western companies -- the asian companies steal your ideas, cheapen up the designs by using cloned parts, recovered parts, sub-par materials (whatever they can do to make it cheaper to manufacture.) There are asian companies selling ESCs in the air market that have selling prices BELOW my BOM costs... Think about that... Their selling price is lower than my material costs ALONE.
It isn't a business you want to get into unless you are doing it simply because you love the hobby. You won't get rich doing this.
micke_b
10.10.2009, 02:39 PM
The plan is mainly to see IF I can do it. 8 layer, thats a lot.
If I manage to do a Brushless sensorless esc at all I'll be very happy. I think I can do one, I'm working as a software designer so I think I can manage that part, it's the hardware experiance I'm lacking, thats why I asked. How good it will be is another question. I will start simple with a normal brushed ESC and go from there.
Just something I allways wanted to do.
e-mike
e-mike's Avatar
10.10.2009, 03:59 PM
very great review...i really want one....
D8t on juice!!
Cartwheels
10.10.2009, 11:41 PM
I've been running brushless for more than a few years now. I have run Shultze, Mtronics, MGM, Quark and some others. It wasn't long ago that we had to modify the ESC's just to make them work properly. Now it is nothing but Castle Creations in everything I own (no mods necessary). Your customer support is top notch too. I have 10 Castle ESC's and counting. We really appreciate your love, keep up the good work!!!
Next, I need a platform that can handle some all out serious speed and a place to run it.
lutach
lutach's Avatar
10.13.2009, 04:06 PM
Patrick,
Fairchild has a 30V MOSFET FDMS7650 with 0.99 milliohm. Can that also be a suitable substitute if availability becomes a problem?
Pdelcast
Pdelcast's Avatar
10.13.2009, 04:11 PM
Patrick,
Nope.
The BSC014N03 actually works well. The Fairchild part has serious issues.
e-mike
e-mike's Avatar
10.13.2009, 04:22 PM
if this fet are used in the mmpro and they are better than other fet's any chance to put them in the mmm to make it smaller.....
D8t on juice!!
lutach
lutach's Avatar
10.13.2009, 04:29 PM
Smaller!!!! I'm willing to send my MMM V1 to get the MOSFETs on them replaced by the NTMFS4933 if Patrick is OK with it . What do you think Patrick? Going by the Continuous Drain Current RJA ≤ 10 s it puts out 52A which would make the MMM (Mine I hope) put out 312A cont. for 10 seconds. Very nice. I'm up for it if Patrick is up for it.
Pdelcast
Pdelcast's Avatar
10.13.2009, 04:38 PM
Time will tell.
