Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
10.18.2009, 02:23 PM
Thanks man...
ANGRY-ALIEN
10.21.2009, 01:01 PM
Hey guys, just an update with some photos. I ran the truck last night on 16 cells with 16/52 tooth combo and it pulled smooth and hard until the Quark started having a little heat issue.
Did not realise it at first when it started cutting out on acceleration and then applying the brake, but after checking the temps... I decided to stop the run and allow it to cool off a bit...
When I re-started it, all seemed to be fine. I had assembled the ESC on the truck with out running a the heatsink that was there before, so it hod no way of cooling down... I will be fixing this tonight.
The current layout pending a heatsink and fan for the Quark:
Stay tuned
pinkpanda3310
pinkpanda3310's Avatar
10.22.2009, 10:13 AM
That's very impressive to look at
I am a little curious though, why have you chosen to run 5s? With all the weight saving you've done it would still be a rippin' truck and you could use the internal bec on the quark.
JThiessen
JThiessen's Avatar
10.22.2009, 11:08 AM
Q- Do your flat head screws sit flush? In some of the pics it looks as though they may not be. It could be an optical illusion - or, I thought maybe those screws have a small radius on the inside corner that may be riding on your holes and slots (as in the motor mount).
ANGRY-ALIEN
10.22.2009, 12:06 PM
Thanks man... I often just sit and stare at it too in amazement .... hmm... I choose 5s because I knew that's what the quark could really handle realistically...
Also, I saw a vid on youtube of a 10xl running 5s (can't find it again though) and it was moving quite nicely around the track... I have seen other 5s setups with similar KVs
getting really good results. I'm not sure what kind of performance I would get from 4s.... Maybe I'll try a 12 cell pack to see how it rolls and give you some feedback.
From the speed calculator:
5s with 14 pinion
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 52
Pinion Tooth Count: 14
Total Voltage: 18.5
Motor KV: 1624
Tire Diameter (inches): 5.65
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 3.71 : 1
Total Ratio: 15.97143 : 1
Tire Circumference (inches): 17.75 inches (450.85 mm)
Rollout: 1.11:1
Total Motor Speed: 30044 RPM
Vehicle Speed: 31.62 mph (50.79 km/h)
Effective KV Value: 1624
KT constant: 0.83 oz-in/A
5s with 16 pinion
Other Ratio: 1
Pinion Tooth Count: 16
Total Voltage: 18.5
Motor KV: 1624
Spur/Pinion Ratio: 3.25 : 1
Total Ratio: 13.975 : 1
Rollout: 1.27:1
Vehicle Speed: 36.14 mph (58.05 km/h)
4s with 14 pinion
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 1624
Rollout: 1.27:1
Total Motor Speed: 24035.2 RPM
Vehicle Speed: 28.91 mph (46.44 km/h) (not very impressive)
Yes they do... the little corner are sitting in the holes and the heads are flush with the surface of the carbon (the holes are just over 3mm).
RC toy
Got Brushes? NOT
RC toy's Avatar
11.27.2010, 04:44 PM
Hi. Any upgrades? What's the thickness of FLM braces?(red line in the picture)
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
11.27.2010, 09:57 PM
6mm...
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
ANGRY-ALIEN
11.28.2010, 01:39 PM
Hey Rc Toy, I measured the chassis brace and got 7mm... regarding upgrades, I recently with some help from Zack got the 'Motherlode' suspension repair kit from UE and
rebuilt the shocks...I saw big improvement in dampening and balance of the truck during acceleration and deceleration... I also employed a set of RPM knuckles with 15mm bearings...
I have done an extensive test with them yet for me to give a feedback... I'll throw the truck around as soon as i get some time and you'll know how well it works out...
Alien
RC toy
Got Brushes? NOT
RC toy's Avatar
11.28.2010, 05:01 PM
I am asking because I am thinking about custom braces and not sure if 0.190 (4.82mm) of 7075 T6 was enough
ANGRY-ALIEN
11.28.2010, 07:46 PM
I am not so sure myself... that looks a question you would have to throw out in the General Discussion section...
Alien
Tags
cc 1520 1y, flm carbon fiber chassis, hacker c50 10xl, ofna spider, ue widetrac
