10.20.2009, 05:13 PM
Originally Posted by DarkRedemptor View Post
Hello,
I would buy a sensored brushless, but I hesitate between 2 controllers
I would like to know if the MMP can handle a T8 2050kV in a Ve8 (weight around 3550g).
I know the MMP is not dedicated to that, but in Europe we need this brushless for most of our racetrack.
The MMP have a Nice footrpint and I think it can made the work well, but I don't know if it can easily handle this kind of motor (the T8 2050kV is a delta wound that drain more current than the Wye wound)
Thanks for your answer
3.5KG = 7.8lbs, so I think the MMpro would do fine with the T8 motor- even being delta wound its still only 2050kv, pushing a pretty light vehicle. I would look in the MMPro beta testers thread and look at the feedback for more ideas.
DarkRedemptor
10.21.2009, 01:30 AM
Originally Posted by Thomas Porfert View Post
As long as you gear conservatively, I don't see a major problem with this. Being that it is a Delta wind, make sure you are running lowest timing (0°). That motor is very close to our 2650Kv motor, so it should be a good fit on a 3 or 4s LiPo setup. I wouldn't be too surprised to see the fan kick on from time to time. Let us know how that works out!
Thomas Porfert
Castle Tech Support
Thanks for your answer, I will try the MMP
