What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.21.2009, 09:20 PM
I like it! I hope it performs as well as it looks. Do you plan on jumping? If so you will want the stiffest springs possible on those center shocks and probably 80+ weight shock oil.
update pics
schofield
schofield's Avatar
update pics - 10.22.2009, 09:06 AM
update:
after about 10 hrs of dremeling my work desk was a mess, but i had everything cut out:
time to clean up and take part count:
the parts are getting fewer and fewer:
i made a jig to keep parts straight, i CA glued them first in place to make sure they work, then drilled and screwed them in place.
here is her stance, with out anything like motors/batteries or servos on it. once everything is put on im hoping the stance will flatten out. then when in the air the rear will move down (like a snowmobile). i will use a bandit body in the end, but for now, an old school hornet body from the mid 80's. the shocks still need to be cleaned/resealed and find the right springs/oil - these are just for mock up now.
kEEp It sUrrEAl
