whipnet
RCCOH.COM
whipnet's Avatar
10.24.2009, 10:21 PM
Originally Posted by 88gtanotchback View Post
it can definitely be done. id say all you need is
Battery boxes #100908
HPI Idler Gear 44t/Shaft Set #100905 (converts your tranny to a single speed)
HPI Battery Box Mount/Cover Set #100909
Motor mount (three pieces)
20t pinion and 44t spur
2200kv motor
Blur esc
and chassis.
i think thats it. If you want you could also upgrade the diffs, and the diff cases. the flux has composite cases, and the bullet proof diffs that HPI just released are great. i just installed a set in my flux. you can also upgrade the shocks to the Aluminum or plastic big bores if you want the real deal flux but the 8 shock set up will work and save you money.
Hey 88, what motor mount and chassis are you referring to? The flux? Looking for something to work with my FLM ext tvps.
Thanks man.
Beat your truck like it owes you money!!
RC Club of Houston
88gtanotchback
10.25.2009, 02:29 PM
Thanks man.
not sure if the stock mount (flux) will work with the FLM. although the kershaw should work. you thinking on converting are ya?
whipnet
RCCOH.COM
whipnet's Avatar
10.25.2009, 08:02 PM
Yep, fired her up the other day and just got frustrated. She's my last nitro.
Gas or BL now. :)
RC Club of Houston
