traxxasrevony
01.01.2009, 02:01 AM
says the ep's are on order so when there in stock ill get one. i got a pro boat blackjack 26 brushless setup i can put in. 1500kv 55mm in length motor. and 45 amp esc. but ive seen up to about 80 amps flo thru it for about 10 seconds and she still works fine.
Jason
09.05.2009, 10:11 AM
do you guys running your blizzard this winter ? I thinked of running mine on 3s lipo with medusa 36-50-3300kv and mamba max esc...
Jason
09.26.2009, 05:15 AM
I would running my blizzard this winter with a medusa 36-50-3300kv and a mamba max esc on 3s lipo geared for 10mph only I need to know im looking for lightweight lipo 3s battery do I still need a 75a to 90a discharge lipo for this low speed no risk to damage something with low discharge lipo like this one --->
Turnigy 3600mAh 3S 20C Lipo Pack ?
09.26.2009, 07:47 AM
I think something like that should be fine- a small motor geared really low really isnt going to pull much current at all. My only question would be does it need to be such a 'high' kv- gearing it so low makes me think it will be under worked and may heat up abit much, maybe something more like ~2000kv perhaps, or maybe just 2s lipo with the 3300kv motor?
Then again, how much do these vehicles weigh?
Jason
10.25.2009, 04:14 AM
ok thanks suicideneil
what kind of runtime do you get guys from your brushless blizzard ?
