I really really really really really really really REALLY like that!
What is the finished weight on that? I think you will find the 1509/2.5Y on 6s to be a great set up for racing. I think it will do 15 min no problem with 3000mah batts geared for race speeds. I have same motor on 6s 2600 in my Ve8 and only put back 1400 to 1600 mah after 10 min. main + couple min. before/after race (small/tight track).
@Marvin: What power set up you going to run in yours?
I'm looking at (hopefully) 3S 5400mAh 40C ThunderPower saddle pack Lipos (bear with me ), a Tekin T8 2650kV, on a Mamba Max Pro. I've got an idea to make it really well balanced when not using a brake servo.
Failing that, either a Hyperion 2600mAh 6S VX pack, or a Thunderpower 45C 2650mAh 6S pack on a Tekin 1400kV T8 with an MMP.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
