Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
nitrostarter
nitrostarter's Avatar
11.09.2009, 11:03 AM
Make sure you gear accordingly for those 40 series Mashers. I know they are heavier and will heat things up if geared too high.
N. Rustler conversion
Kcaz25
Kcaz25's Avatar
11.09.2009, 11:19 AM
Geared for ~39MPH
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
11.09.2009, 04:50 PM
Zack, did you actually re-gear after adding the new wheels? I think nitrostarter was recommending going down a tooth or two to compensate for the extra load.
redshift
RC-Monster Square Tube
redshift's Avatar
11.09.2009, 11:47 PM
Nice ride Zack!
Did you use extra wide fiber tape on the tires.. looks like?
Is it possible at all to tape without turning the tire inside-out?
I've been putting it off, I really need to do it.
Kcaz25
Kcaz25's Avatar
11.10.2009, 12:10 AM
Nice ride Zack!
Means alot, I've seen your work!
Its straping tape. Its packaging tape that has fibers running through it as to give strength. Mine is made by 3M you can pick it up anywhere. Works like a charm NO ballooning! Its better than duct tape as its lighter.
No, can you imagine LOL
It makes a big difference!
redshift
redshift's Avatar
11.10.2009, 12:31 AM
I had considered cutting, say 3 inch strips, and overlapping by like 1/4". It would be a headache I'm sure, but if you could do it inside the tire it would eliminate most of the wrinkling. I need to take one apart and just have a look and quit being a wuss about it lol. Strapping tape would be better, I have plenty of 3/4' wide fiber tape, but that would be a lot of pieces...
I know most people hate Zombie Max tires, and they do balloon at ~30. But after well over a year they show almost no wear. And traction that could almost climb walls...
Looks real good Zack, never enough $ for this stuff is there?
Try and get some video on your mountain adventure!
Kcaz25
Kcaz25's Avatar
Exclamation 11.10.2009, 10:52 AM
Sounds like a all afternoon job to me! LOL Do it! Fully documented w/pics! I'm uneffected by the wrinkling at this point on 4s geared for ~39MPH.
Most people I've encountered love Zombies just never buy em. Really. Badlands normally get the job. Although they roll far to much for me as I have said. So I would have likely been happier with Zombies as far as badlands go. My next tire will be a truggy tire for performance when needed around truggs.
Tell me about the $! Here's my wish list:
UE steering the Proline is great but I need alittle more.
8mm stubs because I bent one of mine
Maybe full front and rear racerX with set back high impact style for the 8mm cvds and added length and geometry and bling of course
MAYBE 7075 t6 billet bulks so that I can use 7075 Knuckleheads
4 more super shocks
Lite Racing shoes and wheels
Couple more bodies 1 bashing 1 racing
RCM cdmotor mount and maybe slipperential
Maybe some lighter ball joints.
A RX box for the hideous wires everywhere.
Fan for MMM
Maybe home-made custom made batt boxes
Maybe some badlands straped up to some skinny wheels and taped.
I've got a crazy idea, check it out:
I might cut off the battery trays so that I could lose the weight and could strap the batts to the sides of the chassis rails like on a Flux with some protective batt boxes!!! Would make For some awesome C.O.G! Then if I wanted I could mount the batts up like one set is now behind the tranny over the monoblock inline for some hot bashin! Would be on my way to one ultimate one of a kind truck!
Whats the public opinion on that?!!
Rivermaxx
11.10.2009, 11:30 AM
I like the side saddle idea is there enough room height wise. What do you need about 160 mm with the box and all?. Have you seen the build wher the guy basically made a LCG flm chassis with carbon fiber. That thing was trick.
Kcaz25
Kcaz25's Avatar
11.10.2009, 11:44 AM
Serum. Yeah. Its one of my favorite Maxxes!
If the braces don't have the height I will just go above, you know let them stick up above the upper deck. I'm thinking of using something off THIS KD PAGE What do you guys think? Maybe the Flux saddle trays?
ANGRY-ALIEN
11.10.2009, 12:07 PM
Hey Zack... You can use the below setup as reference for your mod... I know for fact lowering the FLM's CG will make a big difference.
The actual thread - RC-Monster Maxx - Part Deux
Hope this helps...
Kcaz25
Kcaz25's Avatar
11.10.2009, 12:27 PM
WOW I can't stand it!! I will do this!!! Saddle style will be harder than I thought as there is alittle bit of the top plate that can not really be cut off. I think I will widen my center skid to kind of rest the batts on not necessarily use it as a tray though.
Serum Edition!
Serum's LOW COG FLM
ANGRY-ALIEN
11.10.2009, 12:43 PM
You can make a new gear box skid from a piece of 1/8 aluminum sheet, hang it off spacers and have 'wings' extended from it to facilitate bolting the battery trays on.
Kcaz25
Kcaz25's Avatar
11.11.2009, 11:10 PM
BOMB-PROOF comes to mind! Thinking of doing the winged center skid in lexan...
ANGRY-ALIEN
11.12.2009, 01:28 AM
Aluminum!!! ... The finished product will so much better than lexan...
Kcaz25
Kcaz25's Avatar
11.12.2009, 08:57 AM
Aluminum is the most difficult for me to get. How do you cut aluminum? I've got lexan and I know people who can cut it for me. (i might can cut it myself) How do you cut it anyway? I could order a big 3mm thick sheet of carbon fiber from FullForce. But how would I cut that? Also how do you countersink the screw holes in all three materials? I see some of how you did the cf but I'd like to know in more detail.
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
