11.13.2009, 04:18 PM
We are planning to put a "newbie" mode in the next version of software -- where you can quickly program a "limited power" mode on power-up. This will limit output power to say, 50% of normal power.
I'm thinking that when I take out my electric Baja, I can run it in "normal mode", and then let my 8 year-old daughter take it out in "newbie" mode -- and I won't have to worry about it as much.
What do you guys think??
I like the idea. But, won't that be the same as simply turning down the throttle EPA on the radio? And your FAQ page specifically says not to do that. I can't think of any other way to programmatically accomplish what you are talking about. Personally, it would be easier to simply use less battery voltage and dial in 100% punch control.
Now, when you release your ESCs with data logging, you could use the current measurements to automatically dial in punch control and maybe even some EPA to keep current within reasonable limits.
