sluggie24
sluggie24's Avatar
01.29.2006, 02:17 PM
WOO HOO!!! Glad to hear that Mike. That is what I'm looking for. Stupid power! I ordered the probe clutch with 16t and 18t pinions from you this weekend.......along with a ton or other parts. I did build up the rears already, aluminum diff cases and cups with 3mm screws. The problem I see with longevity with these diffs is the lubrication problem. Any grease put on the gears during assembly will be whipped off when the truck is run. I'm tempted to silicone the cases together and add 1/2 oz. of 70wt gear lube in it. Do you think that would work?
