gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
11.19.2009, 03:29 PM
Been racing this a bit, not as much as I want to and on a small track. I love the truck, won't sell it. I'm going to build a 1/8 buggy, probably an RC8. Not sure if I'll do a custom two pack design like this one or just buy Mike's kit. If it's as good as people say it is, Mike will probably be getting my money this time!
:D
Mbx5t
transtalon
Mbx5t - 11.24.2009, 08:08 PM
Were you having problems with the pin inside the side of the spider gears. The one that goes in the outdrive. I find it to be smaller than the similar buggy or truggy pins. Did you ever break one of those pins? LMK as I am also building one. Thanks in advance.
gtxracer
gtxracer's Avatar
11.24.2009, 08:38 PM
I've never had a problem with the diffs. Actually, this whole truggy has been hands down the toughest thing I've had. I've ran into walls, poles, berms, cartwheeled, endo'ed, slapped the chassis - you name it - and this truggy has laughed at it. The only time I've broken anything is when I've hit the same I beam of the indoor track with the right side tire, broken 2 arms this way. It was driver error and I was going pretty fast when it happened.
I had the outdrive come loose on the rear once, but I put locktite on it and no problems since.
:D
Mbx5t
transtalon
Mbx5t - 11.25.2009, 12:51 AM
Thanks for the positive input.
