Riko
Riko's Avatar
11.20.2009, 06:32 AM
Originally Posted by Unsullied_Spy View Post
MMP + Larger motor = Bad when used in the wrong setup, in 1/8th setups I'd use it only on 6s with lower KV motors when your peak power output is less than 2,000 watts (keep the amps down).
MMM + Small motor = OK. Small motor + big truck = bad. You won't hurt a motor or ESC by using an overkill ESC.
okay, thx dude!
You've been hit by, you've been struck by a smooth criminal
  Send a message via MSN to Riko
