11.23.2009, 03:49 PM
First, welcome to RCMonster!
I personally am not a fan of the novak set up. In both of my crt.5 conversions, I run a mm esc w a 50 series 3300 Medusa and a 1509 Neu ( 3300kv )in the other. Both are plenty fast. The one w/the 1509 neu I run a zippy 3s. The other w/the Medusa I run a 2s TrueRc 5k pack. The 2s truck is my daughters.
You should be able to fit the 5k pack in there w/a custom battery tray.
For my crt.5 I made my own chassis which is 3/4" wider than stock to accomodate the larger batteries. Mike sells trays here and everything else you need to do the conversion
