JThiessen
JThiessen's Avatar
11.24.2009, 12:47 AM
I just checked the HPI website, and the 5B tires are 170mm dia - what is the diameter of these?
5B set up would require switching to 24mm hubs, though. I sent an email to HPI to see if those hubs will fit the Savage outdrives.
BitHed
11.24.2009, 11:30 AM
JT you can use the 5T Savage hubs that take the Baja rims if you have the EXTENDED axles from the XL and the 5T 24mm hex adaptors...You also need the XL dogbones to fit the XL axles...(this also cancels out the possibility of using 8mm buggy axles)...The XL bones means you need the XL diffs and the XL dedicated bulkheads :) this counts me out for right now as i am all X sizes...
...not a cheap exercise and the Baja beadlock weights and the tire weights is kinda scary...I have 17mm Maximzers and dirtbonz (still) and they have added alot of 'noticeable' weight, (though i prefer the beadlock advantage)...
It would be worth a shot if you knew your BL transmission is set up for it...Unfortuntaely mine isnt but i would still love to see this setup in action :)
Thanks for all the news fellas...I still reckon they are a great tire and worth a shot...just make sure they dont go on-road too much i guess :) Certainly enough cmments to make an educated guess at how they go though...Great stuff and thanks for your efforts :)
Desert Rc
12.03.2009, 02:41 AM
wow i didnt know to do the xl conversion you would need xl bulks and diffs, i was just thinking arms and all center and drive bones...hmmm might as well just convert the xl then. Money wise its just not worth the extra dough.
scarletboa
scarletboa's Avatar
12.03.2009, 03:30 AM
all you need to convert a flux to xl length and width is either the TCScrawlers kit or the 1offrc kit and the extended axles. that's it. you are trying to make this harder than it needs to be
Desert Rc
12.03.2009, 03:41 AM
Leave me alone I have done so much research on this damn thing tonight my brain hurts...I need sleep. besides what about the wider stance...I need that dont I?? Anyways Im ordering Lipos, Im poor again for a bit and the wife will call to fight with me in the morning for the bill!! Yea!!
BitHed
12.03.2009, 11:01 AM
...i thought the extended axles needed the fatter bones, connected to the fatter outdrives, connected to the xl bulks...connected to the knee bone, connected to the ankle bone :) Sing along :) We all know the tune :)
Just as a matter of interest, and gettinf back on topic, who is using these with or without airholes in rims or tires? Not wanting to open the whole aireated (spelling?), just how it corresponds yo the Terra Pins...
Actually had a bag of these in my hand in Tokyo the other day and they are lighter tgan GT's which surprised and delighted me LOL
JThiessen
JThiessen's Avatar
12.03.2009, 02:19 PM
The Flux shares the same outdrives from the diff as the XL. That is why I ended up needing the FLM Diff cases for the XL, as they come with a pair of smaller diameter outdrive cups - which still fit the stock drive shaft.
