FG101C
11.30.2009, 03:37 AM
I'll post my setup, i'm extremely happy with it.
The electronics are MM, NEU 1412/1.5 (1850kv) on 3s 5000mah LiPo. First mod I did was a revo mod1 40 tooth spur with a 15 tooth pinion, no way am I stripping gears. Runtime is right at an hour, yep an hour on the track. When I'm done the battery and esc are room temp. and the motor is warm at best.
The reason I'm using the 1412 is because I had it already, a 1409 in similar kv would be a little lighter. The truck is not too fast either, in fact it's near perfect for the Slash. The truck is so light the motor isn't even working hard.
Anyway, hope you get you're Slash running the way you want because they are loads of fun.
Rampokker
Rampokker's Avatar
11.30.2009, 03:53 AM
That sounds like a mean setup! An hour of run time!
I'm really happy with my slash. It's still stock, and I'm happy with the way it goes through the tight parts of the track, but on the faster sections I can't keep up with the SC10's. Can't wait to get a brushless!
