stum
12.02.2009, 05:11 PM
Nope, just assuming - pretty much always a difference btw the 1/8 scale parts and the 1/10 parts. It may slide over them, but they don't stand far enough away at least w/ my 8ight shocks that was the case. If they are the same size or bigger than the eight shocks, get the standoffs now, less waiting later :)
drkdgglr
12.06.2009, 07:48 AM
Received my shocks earlier than expected. The hyper 9 pro front shocks are an almost direct replacement... I can use the stock ste standoffs with these shocks. Can't use the stock ste balls for the rod ends and the balls that come with the hyper 9 shocks need a very slight dremelling of the lower arms (<1mm). It's a 5 second adjustment to the lower suspension arms for some extra clearance.
These hyper 9 pro shocks have a 17mm outer diameter shock body.
Pics:
