Nard Cox
n00b
12.02.2009, 06:52 PM
So guys, tonight I asked mom and dad where I could find a batt for my multimeter, they said they had one in the libra. So I took it out and put it in the multimeter and voila it worked. So I immediate check the fases they were all 0.3 (with the ohm @ 200). I check it with the + and - reversed also, just to make sure.
So just for the heck of it I decided to put the shaft and magnet back into the can and put the endbell on again. That I plugged it into the Esc and give it a little throttle, it seemed smooth again. So I mounted it on the RC8Te and put a pinion on it. Again with the wheels in the air it was smooth. So I put the truck on the ground and what do you guess ..............???.............................it was smooth. So I put the body on and went outside (it's 23:45, dark, little bit of raining, hardly any street light, had a t-shirt on) and drove the truck around a little, it seemed to be fine. Hopefully I will have some time tomorrow to test it a bit more to see whether it's really fine or not.
I'll keep you updated!!
Thanks all for the advise so far!!
