Realistically, how much water can an MMM handle?
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
Realistically, how much water can an MMM handle? - 12.03.2009, 10:59 PM
Hey guys, the title is pretty self-explanitory. I am trying to figure out a way to keep the snow off the speedy in my savage flux. So far I have tried afro-engineering some tape around it which worked alright, but there was still some water on it. I want to keep it water-resistant but still be able to breath. Kind of contradicting if you ask me
So back to my original question though, how much water can the speedy take before it goes to smoke land?
brushlessboy16
brushlessboy16's Avatar
12.03.2009, 11:07 PM
I dont know how much actually amount but heres my experience..
NAy snow that gets close to it melts away. You should be fine
pinkpanda3310
pinkpanda3310's Avatar
12.03.2009, 11:15 PM
Can't you open the case and blob silicon over everything but the heatsink?
I don't get snow, so this is more out of curiosity for myself.
fastbaja5b
fastbaja5b's Avatar
12.03.2009, 11:18 PM
Hard to Say, I have seen some get soaked and last fine, and another fry from a couple of drops in the wrong place.
Say Less, Do More.
HomeGrown
HomeGrown's Avatar
12.03.2009, 11:27 PM
my mm has been soaked while bashing up north it costed me $50 bucks too lol but it can handle quite a bit keep a eye on it tho.. put it in a balloon??
BL Pede, Integy aluminum steering linkages, aluminum shock caps, RPM camber links.
Never Replace Always Upgrade!
12.03.2009, 11:29 PM
You could encase the whole ESC (up to the heatsink and connectors) in epoxy. THat would definitely void the warranty, but no water troubles .... at least not on the ESC...
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
12.03.2009, 11:37 PM
But then my worry is heat. If I were to coat it in anything, I'd wrap it up and plasti-dip it, however I think it would overheat due to no airflow and the fan wouldn't be able to even do it's job. I will see what I come up with and maybe post some pics. Here's to hoping I don't kill the speedy!
Edit:
Ahhh I just re-read your post. You mean coat everything except basically the fan? The fan looks like a perfect spot for water to get in to me....
pinkpanda3310
12.03.2009, 11:39 PM
I'm assuming thermal epoxy would be the best option? Then fit it to an ali casing while the epoxy is still going off.
pinkpanda3310
12.03.2009, 11:42 PM
Edit:
I think he means take it out of the casing first and then coat it, then put it back in the casing.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.03.2009, 11:49 PM
I bashed with a MMM in my E-revo all last winter in the snow with no problems. Biggest recomendation is to cover all holes in the body ( any holes drilled for air flow) since if there's snow on yhe ground it should be pretty cold out and lots of airflow isn't needed. Other idea I have is a box just big enough for the esc and a lid that will go over it, put some spacers in so that the top doesn't seal it off. This will allow room for the wires to go out and some air to get in but snow should have a hard time getting in. If interested in more details I will make a drawing and take a picture to post up
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
12.04.2009, 12:26 AM
Or a box with a big lip on the lid and "spacers". Hmm, good idea's guys!
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
12.04.2009, 12:43 AM
http://www.rc-monster.com/forum/showthread.php?t=24618
my experience
12.04.2009, 01:10 AM
Edit:
Actually, coat everything up to the heatsink. As long as there is a seal between the heatsink and the coating, it's waterproof and there is no thermal penalty. Although, I personally would want to heatsink the BEC. It's switching but it does produce some heat.
e-rev project
12.04.2009, 01:12 AM
shower cap, elastic and plastic worked well for my emaxx. good luck snow is my favorite surface
V0RT3X
Muggy love
V0RT3X's Avatar
12.04.2009, 10:57 AM
http://www.youtube.com/watch?v=LUSmKAvHyEk
