redshift
RC-Monster Square Tube
redshift's Avatar
12.03.2009, 11:42 PM
Still waiting for the Cordless Cord....
dkexige
12.04.2009, 12:59 AM
Lots of research going on for wireless power, you'll get your cordless cord eventually!
.dk
J57ltr
12.04.2009, 01:06 AM
Flashlight for the Blind.
Jeff
PedeBasher
PedeBasher's Avatar
12.04.2009, 01:09 AM
Flux capacitor.
Did you know?
  Send a message via AIM to PedeBasher
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
12.04.2009, 05:48 AM
well i have drawn up some blueprints for ye-ol' internal combustion engine.
sure with electric motors on the rise it'll become redundant, but notice how people are having trouble to let go of petrol?
anywho, my engine is still a 4 stroke, still has pistons but the secret is in the crank. the engine is able to vary it's compression ratio on the move, thus allowing it to run on anything from hydrogen to crude oil.
it will be bassed on a diesel engine but it shall not require injectors because the compression ratio will adjust the timing.
the compression ratio can also be reduced to 0, thus rendering the cylinder inert so as not to waste power.
also, normal engines,when the fuel has just exploded, the piston is at TDC and it cant turn that explosion into power until the piston is about 1/4th of it's way down the stroke. my engine has MAXIMUM leverage at TDC and hence will have a huge power gain when compared to normal engines of the same displacement.
a correctly running diesel can reach up to 50% efficiency which is on par with brushed DC electric motors so it might be a fesable design if i can get a prototype built.
my inspiration was a coke bottle
