what do now
what do now's Avatar
12.04.2009, 11:35 AM
Hi
Well I started to put together my FLM Hybrids Bulkheads today, but befroe I went at it I just checke dto make sure everything fitted together, it doens't.
I using the HB diffs, got my revo stubb axle that I'll be using as out half shaft as I'm using CVD's aswell, not changed the out put cup to the to stubs yet.
Any way here are pics of the hyrids and the problems.
Front
Front
Front
As you can see in the inset, I have marked it red, its too thick the bearing will not go into it.
Rear
Rear
Rear
And here its like FLM never finished the job, marked in red, the opening it way too small.
Now I'm assuming that they all use the same bearing size and not different size bearings for different sides of the truck? Any idea how to fix this without having to send it back to FLM. I'm living in Ireland and it'll take forever, expecially at this time of year.
Apart from the problem shown they are fine the Diff fits into the other side of the hybrids. Well at least I think they are fine, not been able to close them up to tell if there are any other problems.
I'm asking around the forums, so any help would be great.
Thanks
