thzero
12.08.2009, 04:37 PM
Uh why?
The standard ones would have worked fine, although it probably helps to unglue them put some tape on the inside and reglue to keep down the ballooning that will happen (that applies to both sets). Both the Dirt Bonz and the GT2 tires that I tried on my RC8Te while waiting for some Badlands to come in both had serious ballooning issues and that was only on 4s.
The XL tire just has a larger sidewall and it is just going to balloon even more. Probably need to gear down a pinion tooth because of the larger size tires.
Originally Posted by Desert Rc View Post
Oh I got my xl tires also yesterday
Freezebyte
12.08.2009, 04:52 PM
I remember when mine was that virgin clean and new. Didn't last long..... Oh and my diffs leaked too, there's only 1,000k weight in them which is way to light for the Flux. I would put some heavier oil in the diffs before you run it, I run 100k front/rear. And I agree with thzero, those XL tires are gonna strain your tranny, Lipos and ESC with a good chance of breaking them. Gear the pinion down to 18T or 16T
Desert Rc
12.08.2009, 05:00 PM
[QUOTE=Freezebyte;337854]I remember when mine was that virgin clean and new. Didn't last long..... Oh and my diffs leaked too, there's only 1,000k weight in them which is way to light for the Flux. I would put some heavier oil in the diffs before you run it, I run 100k front/rear.
thanks for the heads up on the fluids...cant believe they put 1k wt lol. Yup Minty Fresh is always nice!! Its Crispy!!
thzero
12.08.2009, 05:38 PM
100k seems a bit excessive; don't even run that in my RC8Te's center diff; actually I run my RC8Te with 10/50/7 and have been running my nitro savage with 15/10 front/rear. The adjustment was made because the Savage is about 3 to 4 lbs heavier than the RC8Te.
The 'Triple Diff Basics' thread here at rc-monster is a good read. Just equate the gearbox/tranny in the Savage as a locked center diff for a 50/50 split of power.
As for the taping, since I mentioned it; I think Freezebyte said elsewhere he's using strapping tape, others use duct tape, I have been using Gorilla tape as its a bit heavier than duct tape. Just undo the tires, turn them inside out and run a strip of tape around the inside. It definetly helps.
As for an 'XL' conversion; you can certainly increase the width using the stock Savage XL parts (new dogbones, diff cups, axles, etc.) but you'll need a 3rd party set of TVPs for the Flux (unless Mike makes some that come in the XL length) along with the XL dogbone. Some of the 3rd party TVPs I've seen for the Flux don't always come in the same wheelbase as the XL, but usually come with the required rear dogbone.
Freezebyte
12.08.2009, 05:42 PM
My Flux is a basher and wall climber, so I don't need my wheels unloading on me, hence why I run 100k. I used strapping tape on my GT-S tires, I cleaned the insides of the tires throughly with rubbing alchohol though or the anti aging powder on the rubber keeps it from sticking.
thzero
12.08.2009, 06:22 PM
Ah, I bash too... I just don't wall climb.
Desert Rc
12.08.2009, 11:52 PM
Thats actually a good Tip with the rubbing alcohol. I didnt use that with my xray when I did my strapping and they sound to be lifting a little inside when at speed.
fastbaja5b
fastbaja5b's Avatar
12.09.2009, 09:05 AM
BS!
from someone who has actually run XL tyres on his Flux
They make no descernable difference to the motor or esc temp and eagletree amp draw went up from 120 amp peak to 124 amp peak.
If anything the motor came off cooler
And that was in the middle of a 90 degree day.
Don't make comments without actually trying them first. Perhaps you can scam some from HPI, the tread on your stockers is wearing down, surely that should be warranty!
Say Less, Do More.
thzero
12.09.2009, 10:15 AM
Wow, yes sir, whatever you say sir.
However, it is nice that you've tried it and were able to give feedback on it. I originally made the suggestion based on moving to Big Joes from stock X tires and had to regear slightly because of the larger size. And the Terra Pins are slightly bigger, but probably not quite as heavy either.
P.S. Scamming a quality company like HPI isn't cool, all one does is hurt the company when doing that.
Desert Rc
12.09.2009, 11:53 AM
Thanks for the info guys. I want to get an eagletree...that is some good stuff to track and the information is invaluable.
On the side note. Lets keep this civil. I know we dont all agree on some things (not mentioning it ON PURPOSE) but this is NOT the thread bash others with your opinions. I would really appreciate keeping this on topic.
V0RT3X
Muggy love
V0RT3X's Avatar
12.09.2009, 01:39 PM
BS!
Mine's on the way too, ordered right in time since TCS is out of stock now.
Desert Rc
12.09.2009, 02:26 PM
That's good stuff...lol!!!
Desert Rc
12.08.2009, 04:58 PM
[QUOTE=thzero;337848]Uh why?
Just options is all. I will probably do a XL conversion soon enough....plus I am compulsive with RC stuff. Compulsive is kinda understating. Lots of my stuff works fine but it doesn't stop me.
