12.08.2009, 08:56 PM
Originally Posted by Unsullied_Spy View Post
You could eat coal and shit diamonds, James. The freezer idea is good but if my place burns down I'm SOL, those are hardly fireproof. Not so bad in the event of a burglary though, unless they're looking for my whiskey and hot pockets they'll leave the fridge alone!
Hmm, not sure if shitting diamonds would feel good...
As for fireprrof you are most likely correct, but the fridge does have about 2" of foam in the sides, so it may be a bit fire retardent.
It does have a lock as well!
I am mainly using it as storage before I refinish the guns. Works fine for that!
Disagree.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Disagree. - 12.08.2009, 09:02 PM
I would have to disagree with you there James. Fridges are the worst in fires. They are made mostly of plastic and once the fire gets to them the styrefoam insulation burns like crazy and gives off poisinous fumes that can kill you. Fridges go up like fire logs unless it is a metal encasement fridge/freezer.
SUPERMAXX YOUR LIFE.
Freezebyte
12.08.2009, 11:21 PM
I want this Santa, so I can record my Flux runs in HD
