12.11.2009, 11:39 AM
My main issue is that I have a ton of 5mm bore pinions, and I only buy 5mm bore pinions cause I only buy motors with 5mm shafts...
I guess this 1717 motor can go in the 1/7 scale on road project I have, I was going to use a kb45 xl motor, and had mike enlarge the center of his 2 speed adapter to 6mm to fit that shaft. This has to have a custom made motor mount anyways... Sucks that I cannot use it with the lst (although I could if I use the 2speed adapter with the losi tin gears...)
Just a bit miffed that the info was wrong... Not much I can do about it now, my CC was charged yesterday and I am sure I will see the motor next week.
