Shark413
Shark413's Avatar
12.20.2009, 04:19 AM
Originally Posted by phatmonk View Post
Is the chassis plate from the original nitro CRT.5?
It looks like a stretched CRT.5 chassis. Has the mounting holes in the chassis for the nitro parts (not used).
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
Update
Shark413
Shark413's Avatar
Update - 12.20.2009, 04:20 AM
Finished the body, just a super fast rattle can job, I normally use faskolor but that paint takes weeks to cure and I wanted the body dry so I could get it out on the track tomorrow. I installed the battery tray, motor, esc and tested it on the work bench. One thing I did notice was the stock tires are pretty hard (compound) and much smaller than what others are running. See the picture where I compare the stockers to some Pro-line bow ties for an Associated SC10.
Quickie paint job
Battery tray that fits 3s lipo
Neu 1509 motor and Mamba Max esc
Stock tires and pro-line bow ties (Associated sc10) the Bow tires look wider than normal because there not mounted, but you can see how much taller (larger diameter) they are.
