The start of my dual BL set-up.
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
The start of my dual BL set-up. - 03.16.2005, 06:27 AM
I finaly have some time now to start the process of soldering everything. I guess I'll start with the motors unless somebody suggests I start elswhere. The motors have 3 wires coming from them. I saw in another thread somewhere of a picture that MadDog had posted and it looks like the 3 motor wires go the the 3 wires from the controller. Is there any particular order that they go in?
Do I just solder them together and cover them with heat shrink?
Or do I use some type of connector?
Thanks
RCcarnut
03.16.2005, 07:42 AM
I use the little gold connectors to connect my motor to my 9918. Soldering is always better but I like to change out motors sometimes.
The 9918 you just connect all 3 wires in any order. When you test the motor if it spins the wrong way you can fix that with the programming jumper.
With some other controllers like my 18.61k you connect all 3 wires and if the motor spins backwards you switch any 2 of the 3 wires and that fixes it.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.16.2005, 08:40 AM
I would suggest soldering them. And yes, cover them with heatshrink. As the 4x4nut said ;), you can reverse the motors if necessary quite simply with the red jumper.
JOHNNYMAXXIMA
03.16.2005, 12:33 PM
Sorry for my rookieness.:o
What is the programming jumper?
RCcarnut
03.16.2005, 12:44 PM
It is the jumper near the capacitors.Took me a while to find and I ended up tearing off all my shrink wrap because mine actually fell off during shipping or I lost it unpacking my controller .It is supposed to be red and stick out of the shrink wrap slighty at the capacitors. Mine is now a blue piece of tape attached to a computer jumper
JOHNNYMAXXIMA
03.19.2005, 02:36 AM
Is there such a thing as an on/off switch for a dual set-up (or any BL set-up for that matter)
I got the motors soldered to the ESCs tonight and was wondering if that switch is possible or even recomended. I guess I should have asked this question before I soldered the motors & ESCs just in case the switch taps into there.:eek:
I'm ready for the next step now.
Thanks
RC-Monster Mike
Site Owner
03.19.2005, 10:23 AM
You could wire in a switch, but I wouldn't bother. It will only add a little resistance. I recommend that you test each system seperately (not driving, but check for operation) on the truck and program the controllers seperately as well. You must make sure both controller/motor combos are on the same settings and turning in the right direction. After you are satisfied that both systems are working properly, you can then wire them in parallel to your receiver and test again to make sure both systems are still working (take off pinions or move away from spur gear to test). It is important to check things out at each step to avoid costly mistakes.
Chase023
Chase023's Avatar
03.19.2005, 03:50 PM
That is a good important advice to test each system separately first before hooking them up with together.
Embrace the Speed!
 Send a message via ICQ to Chase023 Send a message via AIM to Chase023
JOHNNYMAXXIMA
03.20.2005, 04:36 AM
Well I made my first mistake....I forgot to shorten the wires.:mad:
Three questions.
First, would I be OK cutting off about half way down the blue wires on the ESCs based off of where I have them placed? (back of the car on the esc plate)
Second, is that a good spot where I have them placed?
Third, should the blue wires be equal length on the ESCs?
Thanks.
Can anybody see the image I posted? (I cant)
RC-Monster Mike
Site Owner
03.20.2005, 10:29 AM
I can't see the picture. You can cut the blue motor leads as far as you want, but remember, it is impossible to uncut them. Once they are cut, they are cut ;) Really, I need pictures to answer you other questions. I always have kept the wires the same length, but honestly don't know if it is necessary.
JOHNNYMAXXIMA
03.20.2005, 02:37 PM
Thats interesting. The picture was there when I was typing the message. Must be my computer setting or something.
JOHNNYMAXXIMA
03.22.2005, 02:46 AM
Hey Mike.
Could you look at my post here and let me know if the wire that I want to use would be OK? If not, what wire (jumper) would you recomend?
Thanks
John
JOHNNYMAXXIMA
03.24.2005, 05:21 AM
OK. Lets see if this pic works. Is this an ok spot for the ESCs? And yes, I did have to un-solder that first motor and shorten the wires.
RC-Monster Mike
Site Owner
03.24.2005, 08:33 AM
That is a fine place to mount the controllers. You may consider something to support the caps, though. If they are just hanging off the edge and you do a lot of jumping, gravity will eventually be the enemy! Maybe a thin sheet of lexan? Just a little extra support.
JOHNNYMAXXIMA
03.24.2005, 08:51 AM
When the batteries are installed, the caps actually rest on top of the batteries because they are stacked. Dont know if that is a good thing or bad thing though having them rest on there.
