squeeforever
squeeforever's Avatar
02.04.2006, 02:30 AM
yea, you can run it reversed. flipping the diffs would have corrected the problem. also, what chassis are you using? gorilla? if im not mistaken if you reverse the tranny your not gonna be able to put it in the rear. you would have to switch the cvds and then switch it to the front.
HotnCold
HotnCold's Avatar
02.04.2006, 10:34 AM
Flip the diffs - Thats probably the easiest way
Hows that "Hope and Change" working out for Ya???
Chris911
02.04.2006, 10:44 AM
Flip the diffs? I did the diff that was in the front is now and in the rear or do you mean somethingelse....and yes i still have the stock chassis.
