cabking
02.04.2006, 09:25 AM
I run a couple of 12v pc fans straight from the main cells.
at 22v they do spin some :030: never last too long though :027:
02.04.2006, 07:14 PM
Put those two fans in series instead. Assuming they are rated the same current/voltage, each will get 11v and will last longer.
Using a resistor is not really bad as long as it is used to control one fan and that fan draws .2A (200mA) or less. To find the resistor value, just subtract the fan voltage from the supply voltage, and then divide that by the fan current. To find the power rating for the resistor, simply square the current, multiply by the resistor value, then double the final value for safety. Usually a two or 5 watt resistor is fine.
If CH3 is being used, hooking them to the output of the BEC. or the output of the on/off switch would be the best choice IMO.
cabking
02.04.2006, 07:24 PM
Now were's the fun in that?
thay last about 2 months..thats good enough for me :003:
