skellyo
skellyo's Avatar
01.08.2010, 03:52 PM
Since the 5T kit weighs 4lbs
Not sure where you got that weight from... The longer TVP's are only 1.5lbs more than the stockers. Where do you see another 2 1/2lbs coming from in that kit? The TVP's are the only significant item in the kit to contribute to increased weight.
I really don't see the issue and think people might be getting carried away - Are the rails that much heavier?
I agree with you Chris. Even with an increased weight of a couple of pounds, the 2200kv is more than capable, especially if you're running 6S and gear for sub 40mph speeds.
Bondo: Also keep in mind that anything other than a 15xx Castle/Neu motor can is going to need a different mount because of the can diameter.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.08.2010, 05:55 PM
I emailed them about weight and the said the kit weighs 2.15ozs, sorry for my typo and that might be Shipping weight ?
The mount will not be a problem, If I have too I can make one myself. Also have a friend of a friend whom works at a metal shop w/a CNC machine
I greatly appreciate all you alls input but no 2 posters have had the same suggestion nor much for straight answers ?
Whats the best viable option weither I run 6s or even 8s
1527 motor but what KV ? ?
ESC, Castle Ice 200 ? ?
